proper water exit
merc 60
I have a merc60 1961, I have changed the impeller and have found that water exits out of the **** hole in a stream but it is also coming out of a pin hole located by one of the nuts that attach the lower shaft to the head.<br />Is this normal? And if not what is the fix?<br /><br />thanks in advance merc60 :rolleyes:
merc 60
Re: proper water exit
Thanks sloopy . Just wanted to make sure<br /><br />merc60 :)
