Re: Proper way to jump start the starter
assuming you dont have any testing equipt.,and to protect the threads on the starter anbd soloniod,remove the heavy starter wire from the solonoid,and use the end of it to touch your jumper cable to.You will get some sparks ,but if you touch it with a good strong contact,the sparking will minimize,you say the powerpacks andcoils test good,have you swapped the coil from the no spark cyl.with one that you know works,if your not getting spark on one cyl,I'd bet that coil is either ,bad,poorly grounded,or the connections are rusty.You could also buy a test button ,simply a push button with a wire that you coud connect to the positive battery terminal,or on the soloniod,and clip the other end to the smaller terminal on the solonoid with the yel.red striped wire ,there are 2 smaller terminal,one is grounded,you dont want that one,if you put a terst button between the positive of the solonoid and the wire to the starter,you might draw too much amperage and burn the test button out if you crank too long,thats why its best to jump to the yel.red
