Propless?
MR nova @#25
My build is comming to an end, and I have no clue what size props to put on this boat. (No Outdrives on the boat when I got it )
What:1976 wellcraft Nova 250 offshore, with twin standard rotaion Mercruiser ford 302's with 4 barrel carbs.
Where: Raratin bay/NJ area.
Thanks in advance
alldodge
From you
Remove drive, put in gear
Rotate drive 10 times counting drive shaft and prop shaft rotations. This will give ratio
jimmbo
WOT Range for Engines of that Era, is likely 3700-4200
I think that Engine was about 215hp
Edit: "(No Outdrives on the boat when I got it )"
Did the Outdrives at least come with the Boat-Motor?
MR nova @#25
Let me check my spare outdrives just to be sure.
MR nova @#25
From you
Copy that, One more question. If I provide the Serial number for the outdives ( The gold stickers are still on the outdrives) is there a database that provides this info?
alldodge
Yes, Merc is the only place and it takes someone with access the the data base to get the info of ratio.
alldodge
Most boats come with the 1.5 unless their real heavy. Props would be in the 19 and 21 pitch. The 302 not being a power house and a 25foot boat, I would go with the 19
Scott06
X2 on the 19” as a good starting point. Might be better to rough in wot rpm with less expensive black max props
