I have a Lowe 1467WT (14' walk trough hull) with a Mercury 9.9 HP 4 stroke that I got that way on purpose so that I could use it at Rim Lakes here in AZ where many lakes are restricted to 10 HP or less.
The first run with the boat at my local lake was at 5100' and I could only make about 4.5 MPH as measured via a GPS. The boat with two passengers and all gear included comes it at around 852#. The boat alone is 262# with the walk through and floorboards.
So on Mercury's advice they had me go to a 4 blade 5.5 pitch prop and thought it would help. The RPMs seem to come up higher but there was no speed increase with the same load. Without a tach I think I hit WOT too as the motor cut out a bit at full throttle and the book says this means it's trying to exceed WOT RPM.
Somebody asked me what it does at a lower altitude so today I drove south to Lake Pleasant which is only 1600'. Same load and the factory prop which is a 9 (I think) by 8.5 will do about 6.7 MPH is all. Not fast but OK.
Most of my fishing will be at 5000-6000 on average and I would like to improve performance.
Would perhaps re-jetting of the carb and perhaps a lower pitched prop gain me anything at all or would I be wasting my time?
PS, While at Lake Pleasant which is a good sized lake. I saw a dot some distance from me and it looked like someone standing on water in the middle of the lake. A guy and his wife were stranded and had been there for sometime they said as their jet ski gave out on them. We towed them in but if it had not been for her yellow bikini I might not have seen her. She said they had been yelling at boats and nobody came near them.
