props stuck???
stugots
ok guys I need a little help/advice here, I have an 88 wellcraft monte carlo, with the alpha one outdrives, last year i put the boat away for the winter, a marina winterized it, when I put it away I noticed one prop spun freely and the other was a little hard to move, I go to start setting her all up and now i notice BOTH are solid as a rock, I cant budge them.
what can cause this? and what does it sound like is the issue? and most important, how much will it cost to repair?
Thanks for all the help guys
Bt Doctur
Re: props stuck???
check the drive oil level and condition , sounds like water in the drive rusted it up.
stugots
Re: props stuck???
if it is rusted whats the game plan for that?
stugots
Re: props stuck???
is there any other possibility of what could have happend here?
Bt Doctur
Re: props stuck???
untill you check the oil or whatever is in there and report back, no.
stugots
Re: props stuck???
ok, im very new to this, where would I check the oil for the out drive? tilt oil right?
matthew colgate
Re: props stuck???
Your drive unit should have a vent screw hole to check drive oil towards the top ......... And your oil drain and fill plug will be on the bottom of unit behind prop that is if its like mine .....
Don S
Re: props stuck???
You will probably need an impact screwdriver to remove the screws.
Here is a link where you can download the OEM service manual for free.
Sounds like you are going to need it. http://www.4shared.com/document/zz_5pj9o/Service_Manual_06.html
attachment.php
stugots
Re: props stuck???
ok, oil looks good, got the trim to move after some playing (just clicked at first) now it moves freely, still wont budge tho, block of wood and a wack with a hammer a bad idea?
Bt Doctur
Re: props stuck???
referring to Dons post above, the "drive oil" looks good ????
Trim has nothing to do with the props
Don S
Re: props stuck???
I am now wondering if you are calling the complete outdrive a prop and that it won't turn with the steering wheel.
attachment.php
stugots
Re: props stuck???
no the steering works fine, i can move both units in both directions using the steering wheel, the trim movies on both as well (both directions) its just the propellers wont spin.
will I damage something if I use a block of wood and tap it with a hammer to try and force it to spin?
Don S
Re: props stuck???
Take the props off and see if the shaft will turn.
stugots
Re: props stuck???
is it possible that shes stuck in gear? how would I tell if it was?
Re: props stuck???
Ayuh,... If it were stuck in gear, it would Lock up 1 way, 'n ratchet back in the other direction...
SeanMcl
Re: props stuck???
Hey Stugots,
No tech advice here, but I'd put in a word none the less: When Don or Bondo are asking you to do things, they are walking you through a specific sequence of Q's and A's. Jumping ahead won't help. Just let them walk you through the steps. It will be much cheaper, and faster to boot. These guys can and will get you to the actual issue.
Bt Doctur
Re: props stuck???
Please do the checks and report results in the order that we ask.
This pic with the blue line shows all the parts moving with the engine running, the prop shaft does not turn untill the shift slider contacts either the fwd or rev gear.so you should be able to turn the prop shaft in either direction freely. If you happened to be in gear, it will lock in one direction and ratchet in the opposite direction.
