Im just about to finish a lengthy boat rebuild with epic proportions.Part of this has been converting the transom from volvo to merc.
The transom has been completely redone and sealed to stop the wood from getting wet.I still believe that no matter what you do with time water will always find a way to soak your transom and rot it.
The wood in the transom is dry as the boat has not been in the water yet,I was wondering of saturating the wood with some fluid that will preserve it,wont freeze and protect it from rotting.For example if the wood is already soaked(wet) with oil it cant fill up with water.I was thinking of drilling a hole on top of the transom in the boat and let the wood soak fluid through that for a couple of weeks.
Has anyone tried anything like this?Any suggestions about what fluid to use,oil,coolant etc?Ideally you would want somethign that wont freeze,has rot protecting properties.
