protective spray for powerhead
cowboyup
I've got a pair of carbed 150 yamahas that i run exclusively in salt water. Is there a recommended spray that i can apply to the powerheads to minimize the effects of corrosion and salt spray? :)
rodbolt
Re: protective spray for powerhead
use fluid film<br /> and use a lot of it.
rodbolt
yep <br /> fluid film<br /> works great but I cuss myself when I have to work on the slimey beasts
cowboyup
Thanks rodbolt. they'll be sprayed this week.
rodbolt
most marie stores should carry it. its good stuff
douglloyd
I'm thinking of using it to delay the rust out on my shift shaft and tilt lock and trim motor.<br />I hav'nt seen it at BW or WM or BUS. I look for it next time.
Dano50
Fluid Film is available nationally through John Deere retail stores. You can also call up the manufacturer toll free at 888-387-3522 to see who carries it in your area. Keep checking the website www.eurekafluidfilm.com. They are putting up a dealer locator so you can find it by zip code. Should be up any day.
andymach23
Can you get this product in the UK also?<br /><br />Thanks<br /><br />Andy
andymach23
I see that there is a UK distributor mentioned on the web site.<br /><br />Thanks
