gettin'wet
- Mar 16, 2010
- 7
Hey guys, been lurking here for a long time, but first post. Tried searching and feel like I need more specific help...
On my '94 Yamaha 15hp (15MSHS) 2-stroke, pull-start - when I pull the cord it will pull out about 6 inches very freely and the I can see the flywheel turning. However, it then comes to an abrupt stop, as if the wheel is being stopped mechanically by some mechanism that I can't see. Also, when it does hit that stopping point it makes a metal on metal clanging sound.
The last time this motor ran was three weeks ago in a fresh water 55 gallon drum and it ran fine and pumped water. I don't know what could have happened since.
I can confirm that the engine IS in neutral, and I've even tried it systematically in every throttle position to see if that was the matter... no luck.
There is a pin that engages the teeth of the flywheel to stop it from starting which is connected to the gear selector (i.e. safety mech. to not start in reverse). I have observed that this is NOT the problem.
Does anyone have experience with this? Any advice is welcomed. I'm a novice at outboards, but comfortable with mechanics, just need to know what I'm dealing with!
Please help! ...and thanks for reading
