Just cleaned the carbs on my 89 50 horse johnson. Ran great the first couple times I took it out after. Now it bogs down at w.o.t
Before I pull the carbs back off and rear clean them, is there anything else I should check first?
Little back story. Motor/boat is new to me. Rebuild the carbs only because it came with kits. No problems before. The motor ran great on the 2nd time out all day until I got back to the boat ramp. Initially thought I was running out of gas, still have 3 gallons though. Motor runs great on muffs. In gear and neutral will rev great out of the water. Took it back out today thinking things were fine and the same thing. Another weird thing is ever once in a while for about 15-20 seconds it'll run w.o.t up to 30 mph at 5500 rpms and hold it for that 15-20 seconds and then start to bog and surge.
Definitely carbs? Or something else? Vent is open on the fuel tank
Thanks for any recommendations
