superpop
Master Chief Petty Officer
- Mar 5, 2006
- 869
Assuming it was either the U joint or the gimbal bearing. How can you tell if the u joint is bad, there is absolutely no play in the joint and it feels smooth as silk. The gimbal bearing is the same way, spins as smooth as silk and no play. So why do I have a growling sound in the drive when I turn or raise the drive. when the drive is down and straight it is silent but the minute I put the drive up or turn the drive hard it growls at me. Anything else it could be, also how do you take the u joints out if I need to, are they pressed in or can i remove a ring to get them off. The have what looks like smooth buttons on the outsides of the joints.
Thanks
Thanks
