Pulled outdrive and now have a couple concerns/questions.
beanz2166
Ok so I pulled my outdrive so I can tackle this gimbal bearing change. Everything was (so far) super easy, but once I got the drive off, now I have some questions. The U joint bellow is bone dry (thats a good thing from what I read here) now I have lots of gear oil/lube everywhere. no oil in the bellows, just everywhere else around the housing. Is this normal? Finally my MAJOR concern is the exhaust bellows, when inspecting there I have no rips tears holes etc, however there is water there. is this normal? thanks guys.
Re: Pulled outdrive and now have a couple concerns/questions.
Nope,.... Oil everywhere is Not normal, it came from Somewhere....
'n the exhaust bellows is wet, both inside, 'n out, Normally...
Btw,.... It'd be nice if ya mention what yer workin' on....
beanz2166
Working on a 1996 Gen II
mercs4mark
Is the gear lube leaking from where the drive gets filled from the reservoir bottle
