Went fishing last weekend and decided now is time to replace carpet for up coming summer fun. Got boat last year and carpet in the stern, in front of the engine and between the rear facing seats was torn and raw decking exposed. Have in mind this has been an AZ boat (as far as I know). Remeber it is a dry heat. Last year as a temporary measure. I pulled up that part of carpet sanded it, treated with wood preservative and painted with rustoleum oil base. She did great all summer with kids getting in and out, in and out..... So pulled up all the carpet today and had lots of delamination of epoxy. Sanded everything down to fresh wood. Wood looked liked barn weathered wood. No soft spots and actually found spots where seems Bayliner shoots in foam. Foam is as dry as this desert. Everythis is covered with white epoxy/paint with flex /sting of blue and some chop strand. When looking in the ski locker. I seems the under side of the deck is not coated. Was this a standard practice of Bayliner? The one piece in the engine compartment is the only piece that I need to replace. I will coat all exposed edges with poly-resin and CSM where I can. Deck is still sealed nice to the boat. THE PLAN: coat deck with poly til tacky, lay a layer of CSM with Poly-resin , dry sand then finish with layer of 1708. Once all cured finish with 20 or 28 oz. rubber backed marine carpet.
Feed back, anyone?
![IMG_20120423_204314[1].jpg IMG_20120423_204314[1].jpg](https://forums.iboats.com/data/attachments/120/120319-7f6d9046dbfcac7bb56a2fbcdb7739f0.jpg)
![IMG_20120428_210804[1].jpg IMG_20120428_210804[1].jpg](https://forums.iboats.com/data/attachments/121/121282-32569cecbacb7e645bccabb762a17fdf.jpg)
