Hey all,
I just bought a 1994 Four Winns Sindowner 215, It needs a new Gimbal Housing Assembly. Everything I've read says to pull the motor in which case the outdrive comes off for that. I'm ordering a new gimbal bearing all out drive gaskets and new bellows. Can anyone tell me anything else I'll need to replace while I have everything apart. What gear does it need to be in before I pull the outdrive? Also part numbers would be great on the gasket kit , bearing ect... I'm in the process of ordering the bearing installer and puller/alignment tools.
Thank you
Thank you
