pulling engine advice
Hard12find
Volvo AQ140A, ready to pull in the morning , pull eng with bellhousing, or split at bellhousing? going for rear main seal.
kenny nunez
Just separate it at the adapter to engine block flange. If it does not want to separate the shaft is rusted into the flex plate . If that happens you will have to remove the upper gear housing and the 6 bolts that retain the adapter housing and pull the whole assembly out.
jerryjerry05
If you have the room??
​Leave it on and while/when it's off replace the bearings and seals.
Hard12find
got engine out with little issue, the bearing in the rear recess of crank is rough, is this called a pilot bearing?
Hard12find
found the p/n in my manual, 11009, got one on order, obviously going to be doing alot of cleaning and detail work, on both boat and engine this week, might get a little boat time this year yet....
kenny nunez
The pilot bearing is for the auto with a standard transmission. Just be sure to grease everything before reassembly. How does the shaft that plugged into the engine feel when turning it. This would be a good time to replace the driveshaft bellows and inspect the universal joints.
Hard12find
thanks Kenny, yeah, checking, cleaning and lubricating and painting everything....did seaplane maintenance for almost 30 years of a 40 year aviation career, real familiar with corrosion control
