Pulling Merc V-150 Flywheel
Outrage 19
Does anyone have a way to pull the flywheel off of a Mercury V-150 with out buying the special puller? Will a standard flywheel puller work if you take out two of the bolts holding the ring around the center hole?
AndyL
Re: Pulling Merc V-150 Flywheel
This one seems to have drawn a blank. If you can wait until Tuesday I will be able to contact a colleague that should have the answer. In the meantime keep the faith and good luck.<br />Andy
