Pulling Mercruiser 5.7 - steering control valve and rear motor mounts
skunkedskippy
I'm in the process of removing my Mercruiser 5.7 sterndrive to do a hull restoration and have a couple questions. Are the circled bolts in the pic the rear motor mounts?
Also, do I have to remove the steering control valve before I pull the engine?
Ayuh,.... The rear motor mounts are the 2 big bolts that run straight up, 'n down, right next to the drive shaft,....
Pull the P/S actuator, After the motor, insteada before,...
