pulling the 4.3 v6
i need to replace the ring gear on my 1999 bayliner 1850. it has the 4.3 v6.
the replacing the ring gear is no big deal.
But getting to it is. does anybody know the best way to pull the motor and detach the outdrive. i need a step bye step walk through.
Thank you
pictures would help aswell
Bt Doctur
Re: pulling the 4.3 v6
All the information needed is in the "Adults section".download the engine and installation manuals.
dubs283
pull the drive
remove fuel, water, electrical connections
disconnect throttle and shift cables
disconnect/remove gear lube monitor line (if equipped)
remove exhuast boot clamps at y-pipe
remove rear mount bolts and front mount bolts
find sufficient equipment for lifting engine
connect a sturdy chain to engine lifting rings
remove engine
Don S
Go to the Adults Only sticky and download manual #25. Section 2A is all about removal and installation.
Also download manual #14. That will give you info for removing the drive. (Yes, you have to pull the drive first)
There are plenty of pictures and instructions. Be careful of the lifting points you use on the engine. Some may look like lifting eyes, but aren't.
