pulling tubes
mike1245
any one ever pull a tube with a john boat if so how big was the boat and what size motor
pmillar
Re: pulling tubes
A buddy has a large (16 ft?) jon boat he has towed a tube with. He has a 35hp Evinrude on back. I'm not sure if he has towed adults but it's no problem pulling kids on it.
rallyart
Re: pulling tubes
I've pulled tubes with an 11' Metzler and a 4 hp.
It's a peaceful ride. The kids weren't that thrilled.
Home Cookin'
Re: pulling tubes
one issue with pulling anything behind a small flat bottom boat is that the object you tow will pull the boat around on turns.
As for tubes, once they are on a plane they are weightless. Getting them up with a small boat is the trick.
Re: pulling tubes
That's a great description. Yes, a tube can be pulled with just about anything, you just gotta' try it and see. When I was a kid we had a 14 ft. V-bottom aluminum fishing boat with a 7-1/2 HP outboard. I managed to pull a ski-board with that so I figure it could have also pulled a tube at a semi-decent speed.
Bayliner1952
Re: pulling tubes
Saw this in RI this last summer. The family looked as though they were having a blast. I think this was there dingy for a much larger/expensive boat.
Wait... how the hell do i attach an image? these forums make things so damn confusing... not link or url... but if have it on my desktop
Anyway, its one of those small 12' rafts with i think a 20hp on it.
Limited-Time
Re: pulling tubes
Try this or this. ;);):D
Bayliner1952
Re: pulling tubes
There, I edited my last post to include an attachment.
I am amazed ther is no option to "insert image" by means of uploading it from your computer
thanks limited
cwilt
Re: pulling tubes
i pulled a tub with 14 ft flat bottom jon boat it had a 25 hp motor. once it got on plane it was good fun. i had to make a turn and then gun it though to get it out on plane.
