pulls to the right
kirmy22
Hey guys, I have a 15 foot trihull with a 55 hp johnson on it, runs great and all, but when you start picking up speed it pulls to the right really hard, the steering wheel turns the motor really easy no problem there. Any ideas what the problem could be. thanks
bear_69cuda
Re: pulls to the right
Check the direction of the trim tab anode, it should be pointed in the direction you want the boat to go.
tawood
2nd that....It should be trimed for cruise, or your most common speed, because you can never get it perfect for all speeds.
Tim
kirmy22
sorry guys you,re talking to a brick wall here, dont know what that is, how do I fix it. FYI it,s a 77, 55hp johnson a 78 trihull 15 ft boat with hydrolic steering thanks again.
JimS123
A trim tab is a fin on the aft bottom of the anti-cavitation plate. Its right behind and slightly above the propeller. Yours is not correclty adjusted, or the tab broke off (its also part of the zinc anode). All you need is a deep socket wrench and 1 minute to adjust it....its connected with a single bolt.
There is a section in your owners manual about it. If you don't have a manual, google outboard trim tab and I'm sure you'll find a picture of it somewhere online.
kirmy22
thanks guys, JimS123, and ziggy. Hope you guys realize how much we appreaciate all of the great help we get here, hope to return the favor someday. thanks again and may God bless.
frank246
Adjust this tab to the side the boat pulls to, in your case to the right (counter clockwise looked from above).
You ll notice that the boat reacts to this but the tab has less efficiency at higher speed.
Then, the trim tab anode and can work in a negative way by producing steering torque. There are anodes without the tab for hydraulic steering!!
JimS123
This is an outboard. I don't know what he means by hydraulic steering, but the only anodes without tabs are used on I/O's with 'Power" steering. He needs the tab to reduce the steering torque.
