Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
While running check to see if their is "fluid" in the vent line running from the fuel pump to the carb. If their is any their the diaphram is bad. Also if their is fuel in the oil the diaphram is bad.
I noticed on the bottom side of the fuel pump there is a black hose cut off with a screw in the middle of it. there is no "clear line" either on this that runs from the carb to the fuel pump. could this be a problem.... is this supposed to be like this ?
