Re: Push-Pull Controls for Fuel & Fuel Return Lines
Thanks Snapper and Rich.<br /><br />Ive been all thru the Teleflex website. They make (distribute?) the critters in the photo above. Special order only from West Marine?
there has to be other sources!<br /><br />I have come across that ball valve Snapper tossed out there, too. The original diesel tank had a valve with a lever like the typical Apollo ball valves. Initially I didnt care either way but I read some of the design parameters for push/pull applications. The torque needed at the valve has to be multiplied by a value relative to the all the bend radii of the cable when it is installed/routed. A small difference in the valve lever size can make a big difference in cable size needed
if I want to do this right.
<br /><br />I was hoping to be able to isolate the fuel at the tank without having to pull up the floor to do it. Maybe I should just hard plumb the fuel line to an area where I want to install the Walbro, Gulf Coast and Racor filters for the fuel polishing system. There should be plenty of valves in that!
<br /><br />Hey Snapper-thanks again for the links on fuel polishing! Found a 24v Walbro in-line diesel fuel pump on Ebay, too.
