Push to choke Ignition Switch
tomb198269
Hello,
I am wondering what "push to choke ignition switch" i need for a 89 Bass tracker 1600 TF. The motor model number is TE60TLCEA 60 hp Evinrude.
Thanks in advance for any help provided.
Regards
Thomas A. Bernauer
Silvertip
Right here on iboats -- just a standard push-to-choke ignition switch. Why are you replacing it? If you simply lost the key, look for a letter code on the switch where you insert the key. Take that code to any Evinrude dealer and they can hand you a key. Or remove the switch and take it to an Evinrude dealer. They have a try-out ring and can find the right key.
tomb198269
Thanks,
It fell out of the dashboard, it still works though. Maybe all I need is something to put the assembly back together?
Tom
Silvertip
It fell out because the nut that holds it in either broke or simply loosened and fell out. Your local hardware store will probably have a suitable replacement nut.
