Hi again,
Before replace my 305 with a brand new 350 i want to ask the following:
I'll keep the old outdrive (228) and the old cooling system with the long exhaust manifolds and the elbows at the back and the thermostat housing with the 8 hoses.Between my ex.manifolds and risers there is a block off plate with only a very small hole as a drain .Since there is no water circulation between them is there any reason to put into the Y-pipe flappers?
Not in order to avoid spending money but because i 'm afraid to dissasemble the Y-pipe due to possible corosion at bolts and possible leaking after puting the new engine .I won't stand this!
