Put oil in pivot housing....
MrPlow403
So in a rush to replace the vertical drive oil I instead tried to put it in the hole which are supposed to drain the water from when winterizing. Step Draining Pivot Housing in the OMC owners manual has you remove 3 water drain plugs. I put it in the top one for picture 37. Any ideas on how much I screwed things up or just let it drain and everything will be fine?
muc
"Retired" Association of Marine Technicians...
Not sure what your working on and don't see a picture anywhere. But I'm guessing it's a Cobra. If so, just let it drain out and you will be fine.
MrPlow403
Thanks Muc. Yes it's an OMC motor and stern drive. The boat service department said the same thing.
