Re: Putting heavier leaf springs on pontoon trailer?
If average loaded trailer and its axle beam is either straight across or chamber down (bowed downward) shape, then existing axle is too under sized. Axle beams should always be slight chamber high (bowed slightly upwards in the center) shape. If slightly bowed high, the axle beam will bow down (to straight across shape) when going across bumps.
If upgrading leaf spring packs (since leaf spring packs should be replaced every 20 years), I'd Scale Weight the average loaded trailer. Then, replace leaf spring packs and if needed, replace axle with next size up sizing. For example: If loaded trailer and boat weights 3,101 lbs, I would upgrade to 3,600 lbs (instead of 3,200 lbs) axle (and new 3,600 lbs leaf spring packs). Thus, allowing some buffer for those double railway tracks and/or extra deep bumps.
Hope this helps.
