Re: QD-13 Compression
If you don't have another gauge...You can do the finger blow off test - the PO Folk way.
pull plugs, move wires out of the way, ground them.
Put finger over plug opening to try and seal the compression.
Pull starter rope - yes, it's awkward. Give it a solid/quick tug.
If it blows your finger off, you have decent compression.
If you can prevent the compressed air from escaping, low compression engine/issue.
Somehow the "blows your finger off" phrase doesn't sound good.LOL I did say ground the wires - although none of us do that, including my friend, Lefty.
On your gauge, is your shraeder valve at the base of your rubber hose loose? That will cause a low reading even if the upper shraeder valve at the gauge is working.
If it is leaking, you'll wind up with 1st pull pressure just repeating itself as the volume in the hose creates an artificially low compression ratio, especially dramatic in small engines.
