Well i have a late 70's quadrajet which had a gasket leak on the base gasket which when i removed noticed was just a gasket meant to be used inside the carb it self which the last owner just threw on the bottom instead of buying the two dollar gasket. So when i installed the proper gasket the engine wouldnt start until i re adjusted the mixture screws, the only issue im having now is the engine idles at 1500 rpm. I checked for vacuum leaks around the carb/manafold and found nothing. the choke opens properly so im considering a carb rebuild, but im not sure if it will help since the carb looks pretty clean. Any thoughts this thing has me stumped, is it possible their is a leak within the carb? oh and i tried the idle screw, its not even touching the plate at this point lol.
