Quantum Holding Water
kingjoe
Still learning all about this one.... I've got a 1990 Quantum and in the center is a storage area for skis.... I figure it also catches water and lets it drain out the rear.... I went to rinse it out and to my surprise the water just kept getting deeper.... Ran a rod through the hole toward the rear figuring it might be clogged, no change..... I looked in the bilge area and that was stone dry.... Any ideas??
Bob_VT
Keep hunting The drain holes are there and do get clogged with debris and leaves. I have used heavy duty weed eater line since the plastic will not damage anything. Be careful using a rod or a hanger since that can and will chew up flotation.
Get the bow of the boat as high as possible and the water should drain. Turn on a bilge pump and see if that has collected water too.
