Quartach?
interalian
I remember seeing a few of these back when I was rigging boats in the '80s. Were they any good? Or were they junk? Be nice to know the exact engine speed - I don't really trust analogue gauges when they get old.
if you want exact engine speed, you need a calibrated tach. the calibration costs more than the tach itself. or simply compare a good shop tach with the dash gauge and adjust the dash gauge as reqquired.I prefer a non-contact photo tach to get me the baseline RPM and I pull the back of the tach apart to get to the trim pot on the circuit board to dial it in if needed.
most gauges in boats cost the boat manufacturer about $5 each for a tach and speedo and a bit less for the other gauges. they are all merely a suggestion as to what is going on. The exception is CAN networked gauges such as Smartcraft technology, etc. those are about $25-50 ea and a bit more accurate as they are taking CAN data and displaying data messages thru a small processor
for stand-alone gauges - analog gauges are no more or less accurate than digital gauges. they both take a pulsed digiial signal thru a bit of simple electronics to convert it to a display. the analog gauges simply convert to voltage and the air core motor moves the pointer. inexpensive digital tachs like the OMC Quartach unit you mentioned are inexpensive digital to analog to digital systems. they are slow to respond and still only a suggestion of what is going on.
however if it makes feel better to see a numerical display vs a sweeping gauge, then by all means, get one. they are no more or less accurate than any other properly setup commonly available marine tachometer
Faztbullet
They constantly failed they why only offered a few years....caused more problems as owner looked at the last digits and complained during summer they lost 178 rpm
interalian
I passed coffee through my nose when I read that. Thanks for the nasal irrigation.
It's time for a new tach as mine sticks when it gets close to 5k. Tapping the face lets it register higher but it isn't reliable. Darned OMC quality - only good for 35 years, then you need to buy a new one.
emdsapmgr
I've run an OMC quartztach for years. Works great. Never missed abeat. Only time you should get an odd reading is when the rectifier is shot.
interalian
ter
Electronically, that makes no sense. I can't imagine an engineer designing something that reads pulses, converts the pulses to an analogue signal, then digitizing the result for display. Much simpler to count the pulses, divide by 6 (or whatever) and then display the result. But I haven't examined the circuit so can't say for certain how it's done on a Quartach.
As for longer term accuracy, all mechanical gauges suffer from friction, loss of magnetism in the meter motor assembly, loss of tension in the hair spring etc. Digital devices have none of these problems.
Jury is still out as for what I will buy. Maybe just open the old gauge and see if I can free up the mechanism.
