Question about exhaust
surfsidewood
86 Sea Ray Seville with a v6 Mercruiser Alpha 1
I was idling my engine on muffs today and noticed that there was water coming from the exhaust hole in the center of the prop. I know the water usually comes from the holes on the gimbal housing when its idling, but never noticed it coming from the prop. Is this Normal? :confused:It wasn't a ton of water, but it was enough to notice. This is my first boat and have only had it a few months, so I just want to make sure everything is ok.
I appreciate all the help. I have been learning tons just from reading other posts. What a great resource this site is.
George
HT32BSX115
Re: Question about exhaust
Howdy,
At idle, most of the water normally will exit at the base of the gimbal mount and if you have an exhaust bellows installed, a small amount may also come out of the center of the prop.
Cheers,
Rick
Ayuh,... It takes the path of least resistence....
surfsidewood
OK Thanks a lot. I just wanted to make sure. I appreciate it.
