question about hydro-lock
flashback
I believe I have a pretty good idea of what it is and what causes it, but when does it occcur? can an engine be running along at say 2500 rpm and just lock up? or does it happen after the engine is shut down and then restarted. I guess i just want to know the symtoms...thanks
Rob Lung
Re: question about hydro-lock
It has happened to me twice: Once just sitting on the middle of lake with motor off and once after overheating. The first time we were all hanging around the aft and a big 35+ go fast went by pretty close. Hydro-loc = big wake+rear end loaded up+worn out flapper valves. Got the flappers replaced and I no longer encourage hanging out on the swim deckin deep water. Second time the engine overheated and when I shut it off I think the heat of the motor drew a vacum and water got past the flapper. Bear in mind that the Sea Ray I have, the motor is very low in the boat and I think prone to loc. I have learned to become manic about it and have not had any problems in a while.<br /><br />I suggest you always have a spark plug socket, and a can of either starting fliud or wd40. If you find youself locked up pull the plugs rotate the motor and shoot some wd in the pistons right away, dry out the plugs and fire her up. Check for water in the oil.<br />My 2 cents
Rusted out risers,+ Cracked exhaust manifolds are to blame quite often....<br />At 2500rpms the exhaust velocity is to high...<br />At Idle, Is a different story....<br />Many times it's a Shut-down motor starting hard, that lets you know..
denniz
Make sure your exhaust shutters are in place...
flashback
thanks for the info guys, reason I ask is I had a little trouble getting cranked up the other day, seemed like a low battery situation or maybe a bad starter relay but after about 3 or 4 minutes she cranked up.. no water in the oil... I'll keep an eye out ......thanks again.......
