question about lower unit
brandon25
i have a 1975 850 mercury, the prop moves in and out about a 1/4 inch is that normal? and when i start the motor the prop will spin if i tap it in a little with my foot but the prop will come back out a little and stop spinning. also it only spins counter clock wise when its in forward or reverse. please help me, what do i need to do to fix it?
Chris1956
Re: question about lower unit
The 1/4" movement is not an issue. I cannot tell from your posting if that motor goes into gear or not. It should rachet CW in forward, spin freely in neutral and turn a bit both ways before it locks in reverse.
Wingedwheel
If it spins CW while in reverse your clutch-dogs may be worn out. Does it pop out of gear when throttled up in reverse?
brandon25
found out that the lower unit froze and messed up the gears and cracked the housing. the cheapest lower unit i have found was $600
