Question about mounting fire extinguisher to helm
WaterDR
Any secret to using the correct screws? Was just going to use a wood screw.
Davem3
Re: Question about mounting fire extinguisher to helm
i use Stainless Steel myself, never rust, break off and easy to undo when changing them.............i think it is like every 3 years if i am not mistaken??
5150abf
Ya, you don't wnat to use a wood screw, in 3 weekd you will get a rust streak runing down your helm.
Just pop into a home improvement store and grab a couple stainless screws.
Tyme2fish
Just be sure to pay for them before you leave the store.:D
coastalrichard
Use a #12, pan head, sheet metal screw and beware of what is behind the area you're mounting to...don't want to cut into any wiring in the helm. Good Luck!
muskiemike12
I used aluminum pop rivets to mount mine.
Georgesalmon
I like #10 X 24 SS thru bolts when I can get to the back side with nylok nuts.
WaterDR
I need to crawl under there and see what I am dealing with.
MH Hawker
Thats dose sort of bring up a question, as far as I know as long as the charge is good and the extinguisher is shaken ever now and then I wasn't aware that it needed changing out.
Davem3
not sure, now that you ask, let me look that one up?
Davem3
I did a little looking and found out that dry chemical extinguishers (According to NFPA 10) have a 12 year life. There should be a date code stamped on the bottom which indicates the year of manufacture.
and a story for you :
and I quote "When I bought my 1648, a decent sized fire extinguisher was included. Looked pretty good, didn't seem to old. The gauge was in the green, and it didnt look like it had been used.
I ended up coming across a new one cheap, so I picked it up. Out of curiosity, I decided to try the old one. I got about 3 seconds of spray, and it was dead. Gauge in the red. Wouldn't have put out a lighter.
Moral of the story: when in doubt, spend the 15 bucks and get a new one. It might save your life and/or boat."
MH Hawker
Well thats why one has to be shaken at a minum of once a summer, the dry powder will settle and clump and if you need it you get nothing but a blast of CO2 or what ever gas drives them. And a brand new one in the box is the very same.
