TwoBallScrewBall
- Sep 14, 2003
- 1,695
On my boat, the lower shift cable comes through the transom inside a hose, like a 3/4 rubber heater-hose type hose. At the end of that hose is a boot that looks like a CV-joint boot, and the red cable comes out of this to the engine shift bracket. My question is what is supposed to seal this if anything? Is there supposed to be a clamp around the boot? I get spalsh of water through the boot when stopped and there's a chop since the fit is very loose around the cable, but am afraid to clamp it because I don't want to bind the cable. I tied it up a little higher for now, but it's as high as it can go and in a 1-2 foot chop, sitting still, I still get water splashing in through it, enough that after an hour or so of fishing I have enough to run the bilge pump for a minute or so. The end of the boot is just about 6-8" above the water line. <br /><br />What's the deal?
<br /><br />Thanks!
