question about OMC Engine
homayoun
does any body know if the OMC 4.3 is the same as GM 4.3 and also OMC 3.0 the belly housing is the same az OMC 4.3? <br /><br />thank you.<br /><br />Harry
JB
Re: question about OMC Engine
Moving to I/O
Yes, OMC 4.3l motors were built by GM, Chevy Div.....<br />Chevy has used the Same Bellhousing Bolt Patterns, Since Chr!st was a Pup......<br />4cyl....<br />I-6cyl...<br />V-6cyl....<br />Sm.bl.V-8s....<br />Big bl.V-8s use the Same pattern, with 1 bolt added to the top-center.....
