Question about removing bow gas tank on hightide
FishBlitz
I have a 1503 hightide with a gas tank up front in the bow. I would like to remove the tank so I can make storage for an anchor. Does anyone know how to remove the tank, do I have to remove the frame on the boat to lift the tank out?
Re: Question about removing bow gas tank on hightide
Ayuh,.... Welcome Aboard,.... Got any pictures,..??
FishBlitz
Do I remove all the screws holding my run rail on as well as the screws toward the stern? Will that allow this to just lift up and over?
FishBlitz
If I remove all the screws around the rub rail, do I need a crow bar to pop it off?
Ayuh,... Donno,.... It looks like it'll be a Major destruction to get the cap off,...
If yer gonna turn that area into Storage, ya need access to it,...
Either cut out a hatch in the deck, or probably better yet, cut an access in the back-panel,...
FishBlitz
Id have to cut a late enough hole to pull the tank out. And then have a huge storage hatch the size on that tank. Is that how you pull the cap off the boat though?
Ayuh,.... Generally speakin',... Yes,...
But I don't know yer hull,...
Some hulls are just screwed or riveted together,...
Others are screwed, riveted, And Glassed together,....
pckeen
Looks like major surgery
FishBlitz
Well I guess there's not other way to find out unless I start unscrewing the rub rail and just kind of figure it out from there. When it comes time to put it back together, do you use 5200 or a spiciest king of caulk?
