Hi,
I have a recently poured Arjay transom and after cutting out the drain hole I set out to install the Garboard drain plug set on exterior skin. There are three holes on the plug that are oriented around the drain hole in a triangular orientation. Apparently, I drilled the pilot holes too small and snapped the heads off of two of the screws when mounting the drain kit, and need to know the best way to back them out if possible?
(still kicking myself as I just got in too big of a hurry trying to get it done before dark and the end of the weekend)
Please let me know what the best practice on this woould be in removing them, thanks!
