Re: Question about switching 1987 Carbs for 1989
Probably not but if you have the model numbers look up the rebuild kits on both sets or the carb numbers like you were buying a replacement and see if they are the same thatll give you a starting point. Carb casting numbers? You could try to check those Im not to sure though
