Question About Wires
pigrge
I have a 1992 Bayline 1950 with a 4.3L serial number OD720478. I removed the distributor last fall to replace a broken brass nipple for the oil pressure sensor. When I removed the distributor, I separated the cap from the base, and removed all wires going to both. I labeled everything but, for some reason, there is an unlabeled black wire that is connected to the vent on the cap. I believe it would go to either the white/green or white/red connector on the base, but unsure which one, if any. Any help on this would be greatly appreciated! Thanks!
Re: Question About Wires
Ayuh,... Got a picture,..??
The only Wires attached to the Cap, are the hi-tension leads...
Don S
I would like to see a picture too.
There are extra wires in wiring harnesses that may not get hooked to anything on your model. That distributor cap vent is just that, a vent. Nothing, especially a wire, gets hooked to it.
captk
thunderbolt 4 had a black wire attached to the long screw that holds the ign sensor,, on the bottom of the dist hsg.
pigrge
My Ingition Sensor, I believe, is over attached to a bracket by my exhaust manifold. But maybe I am wrong. I was told that there was a "bump sensor" placed on the thunderbolt distributor a few fews after 92. Correct me if I'm wrong, but could that be what you are referring to? I'll snap a pic today at lunch and send it over. Thanks!
pigrge
2011-02-18_09-48-45_179.jpgPic of wire. It almost looks like something aftermarket?
Don S
It's not aftermarket, it's after tinkering by someone trying to fix something that didn't need fixing.
Take the wire off and throw it away. It does nothing and shouldn't be there.
