Re: question for P.V. and bomar76
In prior posts keep saying "engine would not crank".<br />Does it crank or not? You never clarify that.<br />If it does not crank over it's NOT the module.<br /><br />If it does crank, but doesn't start, it could be the module. <br />Did you try the diagnostics flow chart when hot?<br />The time to test it is when it is acting up.<br /><br />You could take a can of electrnoics cooler spray out with you and when the symptoms appear again, spray just the module real well with the cold shot and crank engine. If it starts, you know you have a heat related problem with the module and it's time for a new one. If it doesn't, I'd suspect the sensor in distributor.<br /><br />I still think it's the module, but without testing it at the appropriate time....who knows.
