This concerns a previous post by myself concerning a 1995 force 90 Hp S/N OE104323 I am hoping that you guys can explain to me why the engine straightened out and ran correctly when I did the tests specified in Mercury Service advisory 2001-17. This motor had a sneeze at idle and would also stall at idle for no apparent reason. The advisory said to hook up a short piece of clear tubing to the fuel pump input with a tee inserted into the the fuel line. The other leg of the tee went to the fuel supply while the tee branch went to a vacuum/pressure gauge. When starting the motor after hooking the above arrangement up, I noticed a few bubbles coming from the fuel pump which stopped after about five seconds and the motor ran perfectly. I have since replaced the fuel pump and the motor runs as it should. My question is this: What happened with those bubbles, where did they come from and what did hooking up the test apparatus do to make the engine run correctly?
The only thing I can figure is a check valve was sticking or had crud on it. Please provide your opinions.
Thanks
rcb130
Thanks
rcb130
