Question for Woodonglass
dozerII
Seeing how your the enamel paint Guru, are all enamel hardeners the same? In Canada we can't buy Valspar or Majic, After quite a search the only product I could find in the country is available through Offshore body parts and is called ProForm Wet Look.
sphelps
Re: Question for Woodonglass
Their web sight said it was compatible with all acrylic enamal paints .
Should work as well as the others .
GWPSR
Valspar is available at Lowes. There is a Lowes in Regina SK.
Woodonglass
YUP, That's basically the same as all the rest. It'll be just fine for our application. 2oz per quart. Mix every 10 mins for 30 mins then apply. Only mix what you can use in 8hrs cuz after that the Paint is NO GOOD!!!
dozerII
Thanks guys that's what I needed to know. For some reason Lowes doesn't carry it in Canada.
