Hi every one I am from Mexico and , I am New in the boating thing, about 12 years ago a neighbor of mine almost give me for free one duracraft 1959 17 Feet boat and a Johnson 35 hp super seahorse 1959 , I love mechanics so 12 years ago I start working on it , but I had plans to marry and buy a house, etc, etc, etc, so I stop the project at that time, right now I have two little boys (3 and 5 year) the ask me a lot about the old boat, so a month ago I start working on the motor for them (They are very happy) , so far this what I have done:
1)Change set points and condenser, (set to 0.20 In.)
2)Check all electrical system
3)Check all ignition system (Coils primary and secondary ) Working fine Already check resistance
4)Flywheel install (105 Ft- Lbs) torque
5)I already start the motor it work fine , the guy who sell it to me told me it have an oil leakage, 12 years ago if found the leakage it was a defective head gasket , wet sparks , I change the head gasket and head, and I thing is ok, not very sure about
6)The water in the tank where I tested the motor is a oily messy???? , some advise? , the sparks plugs look a little wet right now???, should be a problem?
7)Some smoke coming out I start the engine whit 1:32 relation oil because I want to be oily inside because the time it have been stop the motor.
8)Water is coming out of the pee hole , at the beginning nothing, after is getting hot more water is coming (stat is working) and the temp sensor resistance open, so it is not hot the head , you can touch it for some seconds and if you put water in the outside of the head and is not boiling.
9)The motor works for about 7 minutes then stops, I need to pump in the bulb again and in the carburetor sounds like filling the reservoir , starts again and then stops at 7 minutes,
10)I check the pump , I disconnect the fuel line pump to carburetor and start the motor and I found a good flow of gasoline (not check the pressure already, but I put my finger and pushed gas out in a little stream, the manual said 1 psi at low 2.5 at high . (any advice), I think the float in the carburetor could be stock , but if this is right I should not be able to push gas from the bulb (Is my thinking right), I don?t want to take a part anything before being very sure, because is and old motor and I think in Mexico will be difficult to buy parts.
11)Thanks a lot, any advice
