Re: Question of outboard fuel hose
Wow, I thought that I was thrifty! Part store charges 67 cents per foot for their "premium" fuel hose in 5/16". Get that stuf @ your size. I think fuel injected tube is overkill here. There is only a few pounds of pressure here, possibly NEGATIVE pressure most of the time with a mechanical/vac fuel pump that sips out the fuel.
Some folks use 1/4" on a 5/16" application so the hoses will be tight and not leak. Hell to install. Super for 3 years, but then the stress causes cracks on the inside which make the hose degrade/leak/pop for sure. Quicker in COLD weather. Then, if it starts leaking on the river, you got a serious problem that is harder to fix under stressful and possibly dangerous circumstances.
For $4, Install an in-line fuel filter as well. In my old o/b with vacuumed fuel pump, it's under the hood -- after the quick connect and just before fuel enters the pump.
