I got my 2007 6 hp motor back from the mechanic with the new lower end on it. He told me that it bogged down when put in gear and suggested a carb cleaning and maybe adjustment to air/fuel mixture screw. I decided to do it myself and got it to idle without stalling when you turn the throttle all the way down. Question I have is is there a factory setting for how many turns out the mixture screw should be. I think I turned it out 1.5 turns from where it was. Then I had to set the idle screw almost all the way out. Is there a standard setting for this also.
