Question on millivolt gas valve
rogerwa
I have an old 65000btu propane freestanding propane furnace in my cabin that I want to upgrade to a thrermostat. I also suspect that the valve is not openning all the way (if that is possible) as it does not seem to put as much heat as it previously did.<br /><br />I am thinking that it may be easier to upgrade the gas valve and run the wires to a millivolt thermostat.<br /><br />The thing I am unsure about is how to upgrade (retrofit with new) the thermopile, what valve to use, and how to ensure I don't screw up the existing blower control.<br /><br />Does anyone have any experience doing this type of thing?? i was not able to find any type of information on the heater itself other than what was on the plate as it is a 70's vintage heater.
crab bait
Re: Question on millivolt gas valve
you mean to say the heater has no t-stat,,already..??<br /><br />i guess the main valve can become only 1/2 open.. <br /><br />a new valve will come with a t-couple..<br /><br />shouldn't affect the blower control as this is a separate issue ..
rogerwa
Its got one of those bulb controls. I don't know what their called, they look like a long copper tube. But this is not working as the heater is either on or off. So in the middle of the night when I wake up sweating, I have to get up and turn it off at the valve. When I wake up freezing a few hours later, I reverse the process.<br /><br />There is a dial that is supposed to control temp, but it doesn't work. So I am looking to remedy this..
crab bait
i also have a passive gas heater thru-wall in my shop.. no electric required at all..<br /><br />has a millivolt gas valve an a 'bulb an dial' t-stat.. <br /><br />the bulb senses the room temp an the dail controls the bulbs sensitivity..<br /><br />from the dial ,, there's 2 wires that go to the gas valve.. <br /><br />can JUST replace the 'bulb an dail' very easily..<br /><br />GRAINGERS ...
