question on motor replacement
isimar
i have a 1971 mercruiser and this particular year they decided to install a renault 90/96 with the mercruiser tag on it..don s mentioned that it had a "O" drive also....being that it's next to impossible to get parts for the renault, would a 2.5 or 3.0 bolt up to that outdrive ? i have a line on a good rebuilt motor w/drive for arount a grand, but don't know if the newer drive would match the holes in the stern.
and what is the difference between the O drive and the Alpha units ?
this boat was a freebie and it's in nice shape or i wouldn't bother.
Re: question on motor replacement
Ayuh,.... What you've got don't mix with anything newer...
That's Why it was a Freebie,... it's a pile of Parts, 'n nothin' more...
isimar
if i bought a new mercruiser motor and drive unit, will they fit the bolt holes or am i looking to modify ?
it was a freebie because the 85 yr old gentleman wanted a good home for it because it's been so good to him for so many years, and i help them when they need it.
Ayuh,.... If ya do a Pulleys to Prop swap,...
Ya there'll be abit of modifin', but Nothin' Major...
isimar
what decent engine can you recommend ? i've read here that the 165 is the old 470(?)....
Ayuh,.... a 3.0l from 1991 to present....
A 470 is equal, 'n on par with what you've got now...
isimar
thank you sir, now i guess it's time to look for a 3.0...
Ayuh,... The 91, 'n up gets ya into a current production Alpha, Gen.II drive system...
isimar
thanks again....found a 3.0 (140) on ebay for $500, i'll check it out better.
Ayuh,... Yer already headed the Wrong way,...
Piece mealin' it together gets SUPER Expensive...
Target early 90s boats, 'n find yerself 1 that's Rotten,... Bad wood Rotten...
You oughta be able to find a Complete runner for under $1500.....
That way, ya get all the little expensive pieces it'll take...
isimar
lol....i'll do just that.. thanks
isimar
what am i doing wrong here ? twice i've posted about my mercruiser motor in the mercruiser section and both threads have been moved.
i'd like to know so i don't keep making the same mistake....besides, it's extra work for the mods and i know they're busy enough.
isimar
replace isn't a repair ?
that must be it...ok, guess i need to be more careful.
