I have a 1983 Mercruiser 260 I am replacing the water shutters.(3 inch) since I have to take both rubber tubes off each side and given the age of the boat ..should I be replacing those rubber tubes ? I don't see any damage or irregularities in the shape...except on the right side it appears the y pipe does not line up exactly perfect with the cast part above (working towards the riser) so the rubber tube connection is offset... not a straight shot connection to that next section above it ….
.I would imagine this is OK ? and the rubber is engineered to compensate for these alignment issues ?
Also I am being advised to remove the riser and then disconnect each section as I work toward the shutter
any advise/comment is appreciated
