cowansauto
- Jul 11, 2012
- 38
Somehow the nut and screw on the trigger arm accidentally came loose on my boat recently while breaking in my rebuild. Unfortunately the trigger arm got moved around some so I'm unsure if the timing is correct. The boat was running around 3000 RPMs at idle when I had it at the dock and I wasn't able to correct this on the spot so we pulled back out of the water.
I've looked on this forum, in my service manual, etc and I've learned about the two critical timing marks. Here's my problem though, I do not have the fancy tester that's shown in the factory manual to place the plug wires on and I'm afraid to start running it out of time for fear of burning a hole through the piston! I found the info on using a distributor cap as a multi plug tester but was a little confused about some of the materials they used.
If the timing is way off and I do get it running without taking the plugs and wired out, at WOT to check the timing specs, how long would it take to cause damage? How sufficient is it getting the timing specs by not taking plugs and wires off?
http://motorka.org/doc/mercury/service_manual/jet/SJ90_120_95xr_125xr_831996r1/sec2d.pdf
Thanks for your help!
