question on torque steer??
airtime63
I have a Citation 190 with a 3.0L mercruiser with an Alpha One outdrive. When im on plain around 35-40 MPH it takes almost two hands on the wheel to keep my outdrive from spinning left. Its not bad at slow speeds, but a WOT its pretty bad. This is my first I/O, is this normal or should something be looked at. Thank you in advance.
mkast
Re: question on torque steer??
You can adust the small fin on the sterndrive to compensate for the torque steer, that's if the fin is still there.
Don S
The trim fin on the back of the outdrive needs adjusted.
It's also an anode, so if it's corroded away over 50% it needs replaced.
Ayuh,..........
And,......
They come in Several Sizes,....... If you get 1 of the Larger 1s,.....
Make Sure it Clears the Prop by Atleast a 1/4" or so.............
